DIAdem
Disabling message boxes
   I would like to disable the DIAdem-generated Yes/No modal message box when my application tries writing to a file (i.e. want it to proceed with choice Yes in a Yes/No message box). How do I achieve this? Can anyone help?
Thanks in advance
Venkatesh Murthy B.L.
(3,577 Views)
Hello Venkatesh Murthy B.L.,
Thank you for posting on the NI Discussion Forums.  I am assuming that you are being prompted to overwrite existing data by DIAdem, as I have been in the past.  If this is the case, you can disable the warning message by selecting Settings » Options » General... from the toolbar, and unchecking the box titled Warning if unsaved parameters exist under Program behavior in the General Settings tab.
Chris_G
Sr Test Engineer
Medtronic, Inc.
(3,554 Views)
