DIAdem
Diadem Data Plugin - Loader cannot process the file
Hello.
I have data files that are created by our test rigs that output 1Hz data for many channels. However when i try to use the excel plugin wizard it says "loader cannot process the file".
I have an excel plug in from the NI website but the format is not quite right for my data output.
I am able to create a plugin using the test wizard but get the same message at the end of the wizard.
(975 Views)
Hello Andy,
Please refer to these articles:
Error Cannot Load the File With the Loader in DIAdem - NI
Resources for Writing Your Own DataPlugin - NI
If these don't provide a solution, can you please describe your process/the error in more detail? What data type do you have and which plugin did you install?
Looking forward to your solution!
Messenger2
Messenger2
If someone's answer helped you find a solution or provided insight into an issue, the best way to show your appreciation and acknowledgement is by giving them a kudo or marking their reply as a solution.
(935 Views)
Hi Andy,
Can you post an example Excel file that doesn't play nice with DIAdem's Excel DataPlugin Wizard dialogs?
Brad Turpin
Principal Technical Support Engineer
NI / Emerson
(876 Views)
