10-29-2018 03:27 PM
Hi Group,
I have made a custom vbs dataplugin. On the machine that it was developed, the dataplugin can be edited. When I make a uri and export it (without encryption) and then load into another machine. The second machine, now has the vbs encrypted!
I was expected that since I exported the dataplugin as just "export" and not "export encrypted" that the loaded uri would on a second machine would be able to edit it.
But that is not my experience in DIAdem 2018 64.
How can I edit the dataplugin on a uri installed dataplugin?
Paul
Solved! Go to Solution.
10-30-2018 03:02 AM
The behavior changed for simple double click the uri file.
If the file should be editable you need to use the import button in the DataPlugin Settings dialog.
P.S.: This was done to reduce the amount of editable vbs script in the accessible space to reduce security issues.
10-30-2018 09:24 AM
Thanks Andreas!
