01-04-2013 02:44 AM
I face a problem with the Diadem command DataFileExport. Indeed, I would like to export one or several channels from the Data portal to an Excel file. I followed the help and wrote this very simple code:
Call DataFileExport("C:\Documents and Settings\dzhnw7\Desktop\Example.xls",[4], [Excel])
(my data portal is already loaded and the number 4 is the channel that I want to export).
But I got this error message :
Error in <NoName(2).VBS> (Line: 11, Column: 1):
Cannot determine valid parameters for the the load/save procedure "NOVALUE".
The name of the load/save procedure is unknown. (The name is either not defined or has not been entered correctly.)
Do you know the required modifications which are necessary for this kind of export?
Thank you
Jérémy
Solved! Go to Solution.
01-04-2013 05:00 AM
I assume Excel does not support selective saving.
So there are two solution:
Call DataFileExport("C:\Documents and Settings\dzhnw7\Desktop\Example.csv",4, "CSV")
or using a tdm file and the Excel addin to load data from the tdm file.
The addin is installed with newer DIAdem/LabVIEW versions or it can be retrieved at
01-07-2013 05:11 AM
Thank you very much, it works now. But with my piece of code, I'm not able to make a selective channel export. Indeed, I would like to export only some channels defined in a csv list (first column : channels to export). Here enclose is the code, I get a type error because of the parameter "channel_to_export", but I don't know how to concatenate the channel numbers instead of the channel names. Thank you by advance for your support.
01-07-2013 11:24 AM
Hi Jeremy,
You can find the channel's number property with CNo() command, assuming the channel name you're searching with is in the Data Portal. Here's a minor edit to your script to put that in and build up the selected channel string.
Channels_to_export="" iMax = UBound(Selected_channels) For i = 1 to iMax IF i > 1 THEN Channels_to_export = Channels_to_export & "," Channels_to_export = Channels_to_export & CNo(Selected_channels(i)) Next
Brad Turpin
DIAdem Product Support Engineer
