DIAdem
DataBlCopy converts waveforms to numeric
Hello there,
I am using the DataBlCopy command to copy sections of waveform channels. When I do this the channel that is created is of numeric and not waveform datatype and the associated properties (eg units) are lost.
When I am in View I can use the 'Set Flags' and 'Copy Data Points' buttons to copy the waveform section in the same way but this time it keeps it as a waveform which is exactly what I want.  However I have too much data to do it all by hand.
Is there an alternative command to DataBlCopy which does the same as the View method - keeping the new subset section as a waveform?
Martin
(5,026 Views)
Hi Martin.
When you make a data block copy out of a waveform channel, it makes it into a numeric channel because you've only taken a sample of the y values of your graph.
To fix this problem, you need to make block copies of your time axes that relate to the block copies of your y axes.
After you've done this, you've allocated timing to your selection. Now, you can go to the Analysis tab in Diadem, then Channel Functions, then Numeric Channels<->Waveform Channels, setting the x axis to your block copied time channel and your y axis to your block copied y channel. There's also a command that does this:
Call ChnToWfChn(X, ChnNoStr, [XChnDelete], [WfXStartTimeMode])
I've attached some print screens to show you my process.
ShalimarA | CLA
(4,995 Views)
I was just checking to see if you've gotten any further with the dataBLcopy of your waveform?
ShalimarA | CLA
(4,961 Views)
