DIAdem
Data bind from a user array
Is there a way to bind an user array (instead of SQL_BindChannel) to the data channels?
(4,285 Views)
Hello Larry,
no there is no such alternative. An please be aware that SQL_BindChannel is categorized as an obsolete function in DIAdem.
(4,254 Views)
what is the new function to bind data to channels?
(4,248 Views)
if I use ADO (instead of ODBC) to query data from the database, how can I load that into data channels?
(4,244 Views)
Hello Larry,
the replacement for those functions is ADO. The online help for DIAdem comes with a detailed example showing how to read data from a database using ADO. Just type "ADO" in the DIAdem online help
(4,242 Views)
I've found DIAdem function ArrayToChannels() which may work for this purpose.
(4,230 Views)
