DIAdem
Data acquisition with Diadem 11 lags
To whom it concerns
With my new Dell computer I have problems with lag. Resulting in data loss while measure with Diadem DAC.
Normally I measure with CAN Cases via USB, but the problem also occurs with an easy DAC setup using a slider to generate a wave form.
The signal is regularly interrupted on the screen but also the stored data looks the same.
Best regards
Anders
(5,171 Views)
Hi aeohagman,
Most of our PC's are Dell. I#m using a Dell laptop (Latetude) and use CAN via USB (XNet) with DIAdem 2011. I have no problems. Please can you describe the problem a bit more in detail? Did you install the latest SP for your DIAdem version? You are talking about a new PC. Is there any characteristic feature?
Greetings
Walter
(5,101 Views)
If this is a laptop, please check on your power saving settings. I have seen this happen on other PC's when the computer starts to change the clock frequency of the CPU while DIAdem DAC is running a measurement ...
Otmar D. Foehner
(5,089 Views)
