DIAdem
Data Mining General Questions
I have really been intrigued with DIAdem's data mining capability and I was wondering if someone has any reference information in regards to how data should be save allowing access for multiple users.
Here's a brief example of how I see using DIAdem's data mining capability.
I work with several engineers and we are all conditioning similar test data from a variety of tests.  Typically each each engineer save his conditioned data where ever he chooses.  What I am envisioning is that all of the engineering staff save test data in a centralized location.  Saving the data in a common location would allow me to use DIAdem to search through similar test data based off of test criteria.
I guess my question is am I going about this in the correct way.  How difficult is it to set up DIAdem to mine data from multiple users, using a centralized networked location?
Tim
(5,362 Views)
Hello Tim,
There are two possible approaches to tackle the situation you have described below.
Before I get into the two scenarios, let me ask you a few additional questions.
  1. Will all the engineers you work with use DIAdem to do data mining?
  2. Do all the engineers annotate the data with test criteria?
Saving all the data to a central location is actually not hard at all. You may chose to put different users' data into different sub-directories, or put all the data into the same directory.
Let's assume the "T" drive is your network drive for test data. Let's also assume the "T" drive has a directory called "testdata" where all data will be stored. As song as the file names & extensions that are supplied by all the engineers are unique, you could store all of your test data in the same directory "T:\testdata" and just index that directory.
You could also create subdirectories for all users, something like this:
T:\testdata\User1
T:\testdata\User2
T:\testdata\User3
When you index the "T:\testdata" directory, the DataFinder will automatically (unless you chose not to) index all the sub-directories as well.
If you have multiple DIAdem users, each one will have their own index on their local computer, each one indexing the same data on different machines.
As an alternative, there is the DataFinder Server Edition (DFSE - http://www.ni.com/datafinder/).
- The DFSE is a separate piece of software that is installed on a server class machine within the network. Multiple DIAdem users can connect to the same index on that server at the same time.
- The DFSE uses a more powerful database engine for enhanced indexing and query response performance
- The DFSE is capable of utilizing multiple processors on the server machine for faster indexing
- The DFSE will index data even when the clients are disconnected from the network (laptops used in the field for instance) and will always have the latest files indexed when clients connect to the server
Advantages of the DFSE also include:
- Reduced network traffic (instead of multiple clients indexing the same data on the network on multiple machines, multiple copies of DIAdem can access the DFSE at the same time, sharing the same index)
- Guarantee that the search results on all PCs are identical due to a shared index (if local indexes are used on each machine, they might index different drives and directories within the network depending on the individual configuration of the DIAdem licenses on each PC)
- File access right management through windows file rights, allowing to restrict access to certain types of data to specific users.
Bottom line, you can certainly very easily put all your data in a central location an index it with either a local copy of DIAdem or with the DFSE.
Feel free to contact me directly to arrange for a live online demonstration of this at: (800) 531-5066
Please ask to be connected to me and I'll be happy to show how this works in detail.
Of course, you can also ask additional questions here in this thread, and we can share the answer with other forum participants who might be interested in learning more about this technology.
      Otmar
Otmar D. Foehner
(5,347 Views)
Thanks for the response Otmar.
The DFSE would be a nice addition to DIAdem 2012 but capital is always tight these days.  I was able to add index area into DIAdem however I have run into problems trying to locate a Networked Drive
For example on my machine I have a bunch of mapped drives under the computer directory such as; C:, H:, J:, M: P: . . . .  Z:
These drives I have no problem indexing or accessing in DIAdem
However I have a bunch of Networked drives which do not show up as available items in DIAdem for indexing or search areas.
I have attached a screen dump of what I am talking about.
Any Ideas?
Tim
(5,224 Views)
Accepted by topic author smoothdurban
I figured it out.
I simply added Netwrked path I wanted to index and it works.
Thanks for your help.
Tim
(5,221 Views)
