DIAdem
DIAdem mathscript
Just created a mathscript whwith a fairly simple equation.  When I execute the script, the following error message appears "Cannot transfer result data".  I understand that the MathScript function executes LabView and I do have LabView Professional 8.5 loaded on the machine.  What am I missing?
(6,538 Views)
Hi Chuck@Eaton,
Are you using LabVIEW 8.5 with the MathScript option?
If you are, could you post the script you are trying to execute?
Warm Regards,
Daniel Dorroh
(6,512 Views)
Daniel,
Yes, I am using LabView 8.5 with the Mathscript option.  Confirmed that the license is properly activated.  A simple numeric 1 + 1  = 2 script works.  See attached for the script I am having problems with.  I assumed a waveform is treated as a 1D array.  I did try matrixed array but that also did not work.
Chuck
(6,504 Views)
Hello Chuck,
That particular formula would be easier to handle in DIAdem's Calculation Manager, have you ever looked into that feature?  Exercise 6 of the DIAdem 2012 Hands On Exercises shows an example of how to use it starting at step 6.27.
http://zone.ni.com/devzone/cda/epd/p/id/5393
Brad Turpin
DIAdem Product Support Engineer
(6,475 Views)
I will give it a try.
Thanks.
(6,444 Views)
I loooked for the calculation manager but it does not appear to be in version 11.0.
(6,408 Views)
Hi Chuck,
The Calculation Manager feature did not become available until DIAdem 2010.  Were you able to try Daniel de Gaston's suggestion:
Hello Chuck,
      I am
looking at your input function.
      Efficiency
= Abs(Input_Torque*Input_RPM)/ ((Abs(LW_Flap_Torq) + Abs(RW_Flap_Torq)) *
Abs(Output_RPM)).
      This is a tough concept and easy to make both logical and syntax errors depending on what exactly you want to do.  To do a point wise multiplication of two Vectors or 1-D arrays we need to use the '.*' in order to distinguish between point wise multiplication and matrix multiplication.  I believe the following line of code will work.
Efficiency = Abs(Input_Torque.*Input_RPM) ./ ((Abs(LW_Flap_Torq) + Abs(RW_Flap_Torq)) .* Abs(Output_RPM)).
Daniel de Gaston
Applications
Engineering
Please let me know whether this suggestion worked.
Warm Regards,
Daniel Dorroh
(6,394 Views)
