DIAdem
DIAdem Scripts Naming Conventions
Is there any recommended naming convention for scripts? I am mainly asking about variable names eg. should I include type prefix?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,734 Views)
The only things I can recall and that I would apply :
  1. function names in DIAdem tend to be something like ObjectAction(parameters). E.g ChnSmooth() which smoothes (action) a channel (object).
  2. the "o" at the beginning of objects. E.g "oMyGroup".
You can look at the examples which give a great overview of how you should write your scripts 🙂
Other than that you can still follow those interesting ones : http://www.csidata.com/custserv/onlinehelp/vbsdocs/vbs3.htm. But nothing is mandatory.
CLAMaxime -- Kudos are a great way to say thank you
(2,719 Views)
