DIAdem
DIAdem 2014 ParallelProcessControl Example
Hi
Testing DIAdem 2014's new parallel computing feature. Could someone please provide a simple example for the new ParallelProcessControl object? The help pages are somewhat confusing and the example scripts do not work out of the box as the script files seem to be missing.
Thanks.
/Phex
(5,644 Views)
Hi Phex,
I would suggest that you take a look at the DIAdem SCRIPT Help. There you select the "index" category and look for "ParallelProcessControl". Doubleclick and you should get a window with to possibilities. Select the one which starts with "Object:"
In this help article you also find a small example which shows the usage of ParallelProcessControl.
Best regards
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(5,606 Views)
Hi Phex
If you are using a non German version it may be helpfull to use the examples page differnt from the ParallelProcessControl, e.g.
http://zone-test.ni.com/reference/en-XX/help/370858L-01/parallelprocesscontrol/objects/parallelproce...
In the English version one of the scripts is missing in the ParallelProcessControl topic.
For debugging these scripts have a look at the new command DBM (http://zone-test.ni.com/reference/en-XX/help/370858L-01/comoff/dbm/), that is used in these examples.
Winfried
(5,603 Views)
