DIAdem
DIADEM script to determine rate of change of a signal based on local peaks and valley
The DIAdem: Data Acquisition and Visualization manual describes how to create a block diagram for your measurement task and how to design the visualization ...
Message 21 of 29
(1,172 Views)
Hi Walter,
Thanks for sharing the probable solution, this solution still gives negative results.
Message 22 of 29
(1,168 Views)
Could you please share an example?
Message 23 of 29
(1,167 Views)
Hi joshilpa,
With the two CSV files you shared and the last script I have posted I get only positive values.
Greetings
Walter
Message 24 of 29
(1,160 Views)
Hi Walter,
The attached csv is an example that the script still gives negative dt values.
Could you please suggest what is causing this issue?
Message 25 of 29
(1,121 Views)
Accepted by topic author ebenellis
Hi joshilpa,
That's a good example to have enough test files. Here is a new version.
Greetings
Walter
Message 26 of 29
(1,112 Views)
Hi joshilpa,
Does it work now on your side?
Greetings
Walter
Message 27 of 29
(1,088 Views)
Hi Walter,
Thanks for sharing the modified script but it still fails with attached sample data as it is giving negative dx values this time. Could you please suggest a solution for this?
Message 28 of 29
(1,085 Views)
Hi joshilpa,
I get only positiv values:
Greetings
Walter
Message 29 of 29
(1,078 Views)
