DIAdem
CurveSnippet in SUDs
Hi All,
Is it possible to get CurveSnippet graphics in SUD controls?
I tried to use "Text" control but in accordance with DIAdem help I receive only string filled out of spacebars.
I tried to set "InterpretedTextEnabled" to 1.
Greetings,
Piotr
(3,930 Views)
Hello Piotr,
This is not possible. CurveSnippet can be used only in REPORT where the necessary graphic engine is working.
Greetings
Walter
(3,906 Views)
Hello Walter,
OK, it can not be done with DIAdem curvesnippet functionality, but how it would be done with other DIAdem functionalities?
I would need to know the type of graphics which is used for curve and then external ActiveX control which would support different content, like for example WrapPanel. Then I would use this control in SUD, in the same way as Report controls are used, but instead of setting curvesnippet arguments I would just address type of graphics.
CurveSnippet paints limited number of graphics elements?
Greetings,
Piotr
(3,886 Views)
