02-20-2012 08:04 AM
I am looking to create a master template that includes the company logo as well as other text boxes including information about the test. I want this to repeat on every sheet of the report. The template I saved does not bring this information forward to the next sheet added? I have set this template to be the default upon diadem launch and when a "new sheet" is selected. This is referenced as Master Layout in the Diadem Course Manual (2010 pg 4-22)
Thank you- Dan Trudell
02-21-2012 02:38 PM
Hello Dan, I was able to first create a master Layout using the directions at the following link: http://zone.ni.com/reference/en-XX/help/370859H-01/exploff/examples/masterlayout_example/
After creating the master I would typically just use the "Copy..." command to move that master template down the line. Is this the functionality you were looking for?
