DIAdem
CreateDataFileHeaderAccess (Diadem 2014)
in Diadem 2012 I used the command DataFileHeaderAccess to access root properties of my TDMS files. The properties are in the lowest level (not in groups or channels). In 2012 my code looked like this:
Set oMyDataFileHeader = DataFileHeaderAccess("test.tdms", "TDMS", True)
oMyRootPropVal = oMyDataFileHeader.RootPropValGet("Property_xyz")
If (InStr(1, oMyRootPropVal, "search_string", vbTextCompare) > 0) Then ...
I don't understand how to use the new command. I tried different things, but nothing worked for me. For example:
Set oMyDataFileHeaderAccess = CreateDataFileHeaderAccess
Set oMyDataStore            = oMyDataFileHeaderAccess.Open(files(i),"TDMS", True)
Call MsgBox(oMyDataStore.RootElements(1).Properties.Item(1).Name)
My properties don't appear in the branch RootElements(1).
oMyDataStore.RootElements(1).Properties.Count  also returns the wrong size in my case.
Thanks in advance!
Karlheinz
(5,970 Views)
Accepted by topic author kawosch
Hi kawosch,
Try this in DIAdem 2014 and later:
Set TdmHdr = CreateDataFileHeaderAccess()
Set DataStore = TdmHdr.Open(files(i), "TDMS", True)
Set DataRoot  = DataStore.RootElements(1)
Set DataGroup = DataRoot.Children(1) ' first Group
Set DataChannels = DataGroup.Children ' first Group's Channels
MsgBox DataRoot.Properties("Property_xyz").Value
Brad Turpin
DIAdem Product Support Engineer
(5,945 Views)
Hi Brad,
thanks a lot, that helped :-).
Karlheinz
(5,925 Views)
