DIAdem
Create TDMS File from .NET5 allways get error DDC_StorageCouldNotBeOpened
Hello
I'm using the c_dll_tdm to create a TDMS file in c#, and it works fine for a .Net Framwork 4.5 project. But if i try to use it in a .NET5 project. The function DDC_CreateFile return a DDC_StorageCouldNotBeOpened error.
If try to create an existing TDMS file, the error code changes to DDC_FileAlreadyExists error.
Any Idea?
JC.
(2,141 Views)
Accepted by topic author Runess
access_ni_tdm_c_dll_with_dot_net
uses pinvoke-interop-assistant to create a .net wrapper.
At least when I created the code I run it with .net 5 (Core) which worked.
Maybe it hels somehow.
Greetings
Andreas
(2,089 Views)
I created my own wrapper and works as expected.
Thanks.
(2,064 Views)
