DIAdem
Create Data Plugin for Labview BIN files?
Hi all,
I have a DAQ application here which saves aquired data to Labview binary files (it uses a typedef to define the data structure and uses the Labview write to binary file VIs). Currently, I'm using a small Labview tool to read these files and convert them to TDM(S) before analyzing them in DIAdem.
Now, it would be neat to have a data plugin which can directly read these binary files. Is there a possibility to create one in an easy way (similar to using the Labview read from binary file VIs - you just show them your data structure typedef and you're done)? Did anyone do this before?
Thanks for any help!
Stefan
(4,488 Views)
Hi Stefan,
we are currently developing an SDK to create DataPlugins in G (LabVIEW). This will allow you to use the read from binary file VIs to read-in the data and map it to the TDM model with the help of the VIs provided with the LabVIEW DataPlugin SDK.
We have a prototype of this SDK ready to work which needs LabVIEW 8.5.x.
If you have LabVIEW 8.5.x, please reply and I will be happy to provide you with the LabVIEW DataPlugin SDK.
Greetings from cloudy Aachen
Stefan
(4,479 Views)
Hi Stefan,
ja, ich habe Labview 8.5.1 und würde das SDK gerne testen!
Danke & Gruß aus dem ebenfalls wolkigen Schweinfurt,
Stefan
(4,477 Views)
Hi StGl,
Actually, if the binary file structure is rather simple, you would get better functionality from a 15 line VBScript DataPlugin.  The awesome thing about the LabVIEW DataPlugin API is that you can re-use complicated G-code that you already have.  In this case, I'd bet that the file is pretty simple and that the effort of reprogramming the read algorythm in a VBScript DataPlugin would be minor.
LabVIEW DataPlugins add another memory copy to the DataPlugin read process, and they are currently not as efficient when reading a select index window of data values.  If I were you, and the binary data file could be read with DirectAccessChannels in a VBScript DataPlugin, I would do it that way.
Of course, if it turns out that your binary structure is not super-simple, then re-using the G-code you already have would make sense.  The LabVIEW DataPlugin API has a learning curve to it, both in the paradigm of the VI usage and in the details of the build process.
Brad Turpin
DIAdem Product Support Engineer
(4,452 Views)
