DIAdem
Convert Wafeform X-Values
 Hello:
I am processing data in .MME format.  Each channel loads into the data portal as a waveform channel.  My issue is that the x-values for the waveform are in "seconds" and I require everything to be in "ms."
Is there a simple way to do this conversiom?  I've tried some more complex, roundabout ways to solve the problem but I'm hoping for a more elegant, succint solution.
Alex
(4,915 Views)
You can click at the unit property (the text in the list of properties of a channel). Then a 3-dot-button appears. If you click on that you get a dialog which let you convert the unit "s" into "ms".
Greetings
Walter
(4,905 Views)
I failed to mention that I'd like to perform the conversion in a script, if possible.
It's part of a larger dialog box and I'd like to have as little user input by the test operator as possible.
Alex
(4,903 Views)
Yes, this is also possible via script. The command is ChnUnitConvert
Greetings
Walter
(4,898 Views)
Thanks for the reply.
Will this work even for a waveform channel where I'd only like to convert the x-value?  It seems to me that with the command you've supplied, I would only be able to convert the y-values of the channel.
Alex
(4,896 Views)
Accepted by topic author AlexVander
Good point. In this case you must use the command ChnWfxUnitConvert
Greetings
Walter
(4,889 Views)
