DIAdem
Channel write protection - still there after using ChnValExpand
When I load certain datafiles, some time channels appear as write protected.  I use ChnValExpand which appears to work (the little symbol disappears from the channel name).  However, the channels remain protected and I am unable to write to them.  How can I remove the write protection?
Any help is appreciated
Thomas
(3,229 Views)
Accepted by topic author mrme
Hi Thomas,
It seems that this is a bug. If you some similar code like this below, the you get an error regarding write protection:
dim oChn
set oChn = Data.Root.ChannelGroups(1).Channels(1)
call ChnValExpand(oChn)
oChn(1) = 5
The workaround is to redefine the object variable oChn like this:
dim oChn
oChn(1) = 5
The all is fine.
Greetings
Walter
(3,217 Views)
Hi Walter,
Thanks!
Thomas
(3,162 Views)
