DIAdem
Channel copy within VBS- Kanalbereiche kopieren in VBS
diadem 9 doesn't provide a autosequence "areacopy" as diadem 8 did. How can i include areacopy in an autosequence in diadem 9? TNX
gnometto
(gnometto tutto, mica un pezzetto!!!)
(4,374 Views)
Hi
Command: DataBlCopy
The DataBlCopy command replaces the DataAreaCopy command. (The old command still works)
Copies a data block from channels and inserts the data block into other channels. DIAdem overwrites existing values.
Command: DataBlClpCopy
The DataBlClpCopy command replaces the DataAreaClpCopy command.(The old command still works)
Copies a data block from channels into the clipboard.
Hope this helps
Winfried
(4,367 Views)
I’ve already found this command, but I can’t make it work as I wish.
I need a subsequence with interaction, where I can select on the view window the area I want to copy.
Diadem 8.1 example:
Call VIEWLAYOUTLOAD("view_to_set_cursor .LVD") '... VIEWFILE
call ViewCursTypeset("Band")
Call ViewCursPosSet(3.0576,0,19.3539,0) '
Call ViewUpdate() '
call interactionon
Call ScriptStart("areacopy","")
how can i do that within diadem 9.1 vbs?
tnx for your help!!!
gnometto
(4,366 Views)
Hi
The AreaCopy script does not exist in 9.x but the functionality is still available. Perhaps this script helps you as a first step. Or you call the copy function in VIEW interactively.
Call VIEW.LoadLayout("view_to_set_cursor .LVD")
VIEW.ActiveSheet.Cursor.Type="Band"
Set SheetObject=VIEW.Sheets(1)
SheetObject.Cursor.X1=3.0576
SheetObject.Cursor.Y1=0
SheetObject.Cursor.X2=19.3539
SheetObject.Cursor.Y2=0
Set SheetObject=nothing
Call VIEW.Refresh()
Call wndshow("view")
call interactionon
set oMyCurve = View.Sheets(1).Areas(1).DisplayObj.LeadingCurve
ixChnNo = oMyCurve.XChannelNumber
iyChnNo = oMyCurve.yChannelNumber
iX1Value = pno(oMyCurve.XChannelName, VIEW.Sheets(1).Cursor.X1)
iX2Value = pno(oMyCurve.XChannelName, VIEW.Sheets(1).Cursor.X2)
msgbox iX1Value & " " & iX2Value
call chnalloc ("x_copy")
call chnalloc ("y_copy")
call DataBlCopy(ixChnNo, iX1Value, iX2Value - iX1Value, "x_copy",1)
call DataBlCopy(iyChnNo, iX1Value, iX2Value - iX1Value, "y_copy",1)
Winfried
(4,354 Views)
It works well!!!
How can I set the flags automatically for the selected area?
Furthermore, i have to expand this for the copy of more channels in the same window, and to give the name X_copy_channelname Y_copy_channelname to every copied channel.....
why diadem 9.X doesn't support the old commands of diadem 8.X?
Thank you for your quick and competent support!
gnometto
(4,352 Views)
Hi Gnommeto
Try this
Set SheetObject=VIEW.ActiveSheet
Call VIEW.Refresh()
wndshow("view")
call interactionon
For Each oMyCurve in SheetObject.ActiveArea.DisplayObj.Curves
i=i+1
iX1Value = pno(oMyCurve.XChannelName, SheetObject.Cursor.X1)
iX2Value = pno(oMyCurve.XChannelName, SheetObject.Cursor.X2)
call chnalloc ("x_copy" & i)
call chnalloc ("y_copy" & i)
call DataBlCopy(ixChnNo, iX1Value, iX2Value - iX1Value, "x_copy" & i,1)
call DataBlCopy(iyChnNo, iX1Value, iX2Value - iX1Value, "y_copy" & i,1)
Next
Winfried
What is the meaning of gnometto tutto, mica un pezzetto!!!
(4,343 Views)
Danke, funktioniert prima!
gnometto
(4,333 Views)
