DIAdem
Canceling the DIAdem Evaluation period early
Without going into a large amount of detail, is there a way to prematurely end an Evaluation period? I have an network license but, since I told DIAdem to allow Evaluation before I received this network license, I am receiving a prompt telling me my license is limited.
I want to cancel Evaluation and the remove the limitation from my software.
Thanks.
    - Kevin
(3,201 Views)
Hi Kevin,
You should be able to cancel your evaluation period by going to NI License Manager and de-activating your license from there.
This process will look a little different depending on what version of NI License Manager that you're using, but if you have anything below version 4.0, this KnowledgeBase Article should help you out!
Andy F.
Applications Engineering
(3,159 Views)
Hey Andy,
I do have 4.0, but when I right click either the CAT add-on or the "Professional Edition with DAC Bundle", which are both under Evaluation, it only gives me the option to activate my license. I only have a license for the Advanced Edition, which is activated.
(3,157 Views)
Hi Kevin,
I noticed the same behavior on my computer, but was able to work around this by following the steps outlined in this KnowledgeBase Article.
Let me know if you encounter any issues with this process!
Andy F.
(3,150 Views)
