取消
顯示結果
搜尋替代
您的意思是:
Can't get AutoQuit to behave like it should.
If I use the AutoQuit command in a subscript, DIAdem ends the subscript but not the main script.  Help describes the behavior as ending both the subscript and the main script.  What gives?
0 積分
1 條訊息(共 9 條)
4,790 檢視
I should add that I am using DIAdem 10.
0 積分
2 條訊息(共 9 條)
4,781 檢視
Hi Sarm,
The behavior described in the Help is what occurs on my computer every time I run AutoQuit() in a Subroutine-- both the Sub and the main VBScript terminate abruptly.  Is the main script on your computer a VBScript being run from the DIAdem-SCRIPT editor, or is it something fancy like a script being invoked from an external compiler through DIAdem's ToCommand OLE Server?
Send over your code, and I'll look for clues,
Brad Turpin
DIAdem Product Support Engineer
0 積分
3 條訊息(共 9 條)
4,772 檢視
Attached is a sample script.  I run MainScript.vbs by going to the Script Panel and pressing the "Execute File" button and selecting MainScript.vbs.
I receive 2 messages as output.  "Message 1" and "Message 3".
Let me know if you need more info.
0 積分
4 條訊息(共 9 條)
4,758 檢視
Hi Sarm,
I can reproduce your problem behavior now on my computer.  I didn't realize that happened with ScriptStart() because I rarely use ScriptStart() myself.  I usually use ScriptInclude(), where the AutoQuit() function behaves as expected.
Here's your example rewritten with ScriptStart(),
Brad Turpin,
0 積分
5 條訊息(共 9 條)
4,721 檢視
Brad,
It is not clear from your answer if you believe I should be using the ScriptInclude command instead, or if you are suggesting that I am using the ScriptStart command incorrectly and the AutoQuit() command will not or should not be working as I am using it.
Does this mean I can not use the ScriptStart command any longer.  The AutoQuit() command was working in this manner through version 8 (I’ve gone from version 8 to version 10, skipped 9).  I’d rather not change our current scripts unless absolutely necessary as it will not be an insignificant endeavor.
I use ScriptStart to declare and free variables as needed trying to keep the variable count down.  I am using around 800-850 variables.  Does DIAdem still have a limit of 1000 variables that can be used at once?  If I cannot free variables as I do now using the UserVarFree() command I may be in danger of reaching the 1000 mark.
Can you tell me if the AutoQuit() command SHOULD be working as I am using it and that it not working indicates a bug. Or has the support of the AutoQuit() command as I am using it with the ScriptStart command no longer supported.
0 積分
6 條訊息(共 9 條)
4,713 檢視
Hi Sarm,
I've spoken to R&D further about this, and it turns out that unbeknownst to me there was a bug in DIAdem 10.0 that resulted in the parent script not aborting after the AutoQuit() in the Subroutine aborted the Subrountine.  This has been fixed and should work correctly in the released version of DIAdem 10.1.  Unfortunately, it does not appear that the fix made it into Beta1 (still doesn't work on my computer), but it should make it into Beta2, which is only a few weeks away.  I'm not sure what to suggest for your existing code.  The DIAdem 10.1 Beta is extremely stable.  Actually the alpha was also extremely stable.  So if you have SSP are are going to be upgrading anyway, you could switch to DIAdem 10.1 and just reuse your existing code with no changes.  Or you could implement the changes to your code so that it runs on DIAdem 10.0.
Sorry for the inconvenience,
Brad Turpin
0 積分
7 條訊息(共 9 條)
4,654 檢視
Ok, thanks for the info.  I am going to try and hold out for version 10.1.  Is there any estimate when it will be available?
0 積分
8 條訊息(共 9 條)
4,646 檢視
Hi Sarm,
Like I said, the Beta2 for DIAdem 10.1 will be available in a few more weeks.  The actual release will be several more months.  I'd recommend at least checking out Beta2, even if you don't use it for production until it's released.
www.ni.com/beta
Brad Turpin
0 積分
9 條訊息(共 9 條)
4,614 檢視
