DIAdem
.CSV missing time
Hello together,
I'm doing measurements of blood flow. It is possible to export files from the Measurement-System as .DAT Files. I have the File Format Description of the .DAT File so I´m able to write the Values into an .CSV File using FreeMat. But there is no possibility to add the time to the .CSV File so I generated a TimeChannel in DIAdem Analysis. The Graph looks fine, but if I use DIAdem Analysis Integration the Values I get doesn´t make sense. I hope somebody can tell me how to add the Time the right way.
(5,235 Views)
To get suitable graphs for the measured data and its integration, follow these steps:
1. Create the time channel with the tool "Analysis -> generate numeric channel", adjust the settings as in screenshot "2013-05-15 14_21_52-Numerischen Kanal generieren.png"
          way of channel generation: equidistant, start value: 0, end value: 60, number of values: 12501, unit: seconds
2. do the integration with the generated time channel, adjust the settings as in screenshot "2013-05-15 14_24_40-Integrieren.png"
          x-channel: [1]/LinearGenerated (this is the time channel), y-channel: [1]/Ch0 (this is the channel with the measured values)
3. open View in DIAdem. First click on the time channel, then press the Ctrl-Key, click on the other two channels and drop them into a 2-axis-diagram.
          The result is shown in screenshot "2013-05-15 14_28_47-DIAdem - [VIEW_   Flow.TDV].png"
(5,204 Views)
Did you consider to create a DataPlugin which can read the DAT file directly and, assuming there is sufficient information in the DAT file, would generate the time channel while reading the data ?
You mentioned that you have access to the documentation of the .DAT file format and you have exampel files so creating a DataPlugin should be possible.
Andreas
(5,178 Views)
