DIAdem
CSV Export with Units
 Brad, I don't see an option in Diadem 2018 for exporting properties as a row.  The only options i see are Separator, Decimal Separator, File Encoding, Time format, and Enclosing text with double quotes.
Is there a secret parameter available in scripting export channel properties as a row of a csv file?  Or is your workaround still the only way?
Message 11 of 15
(1,733 Views)
Sorry DIAdem 2018 still does not include such a feature.
So the workaround is still the only way.
Message 12 of 15
(1,726 Views)
Hey there experts,
I'm quite new to vbs scripting but now I have the task to rewrite our old script from 2012.
I added the following code to export my data as an csv file:
Option Explicit  'Erzwingt die explizite Deklaration aller Variablen in einem Script.
Dim oMyChannelList, dateiexcel, pfad, versuch
Set oMyChannelList = Data.GetChannels("[2]/[1]")
Call oMyChannelList.Add(Data.Root.ChannelGroups(2).Channels(2))
Call oMyChannelList.Add(Data.Root.ChannelGroups(2).Channels(3))
versuch = "Versuchsnummer"                                                       'kann im biax script entfallen, da der jeweilige Versuchsname in Zeile 95 an das Script übergeben wird.
Dim MyFolders()
Call FolderCreate("C:\Users\Andre\Desktop\Excel Export\" & versuch & "\")        'erstellt einen neuen Ordner mit dem Entsprechenden Versuchsnamen
ReDim MyFolders(1)
MyFolders(0)=("C:\Users\Andre\Desktop\Excel Export\" & versuch & "\")            'muss im Script entsprechend auf den Ordner Versuche angepasst werden
Call DataFileSaveSel(MyFolders(0)& versuch & ".csv","CSV", oMyChannelList)
Call DataFileSaveSel(MyFolders(0)& versuch & "eng.csv","CSV", oMyChannelList)
function CsvParameters(byval filePath, byVal lang)                               'konfiguriert die CSV Datei in Bezug auf Trennzeichen und Spaltentrennung etc.
  select case lang
    case "ger"
      CsvParameters = "<filename>" & replace(filePath, "&", "&amp;") _
      & "</filename><decimalpoint>,</decimalpoint><delimiter>;</delimiter><timeformat>DD.MM.YYYY hh:mm:ss</timeformat>"
    case "eng"
      & "</filename><decimalpoint>.</decimalpoint><delimiter>,</delimiter><timeformat>MM/DD/YYYY hh:mm:ss pp</timeformat>"
    case else
      CsvParameters = filePath
  end select
end function
But as always the export is without units. Now I don't know where to fill in the Code that Brad provided many years ago, or is there a better method by now?
Thanks in advance and I would appreciate any help! 😉
Message 13 of 15
(1,612 Views)
Hi Andre,
My script was so old it wouldn't run in DIAdem 2020, so I had to update it and simplify it some.  See if this gives you the idea how to hot-swap the next few header lines for the name of the last channel being exported.  The only down-side is that any "/" characters in the get turned into "\" because of the Group/Channel requirement to be unique.
OPTION EXPLICIT
Dim FileNamePath, HeaderLines, Group
Call DataDelAll
Call DataFileLoad(AutoActPath & "Example.tdm")
FileNamePath = AutoActPath & "Example.txt"
HeaderLines = "Version 1.10" & vbCRLF & RTT(TTR(CurrDateTime), "#yyyy-mm-dd hh:nn:ss.ffff")
'Set Group = Data.Root.ActiveChannelGroup
Set Group = Data.Root.ChannelGroups(1)
Call GroupAsciiExport(Group.Channels, FileNamePath, HeaderLines)
Call ExtProgram(FileNamePath)
Sub GroupAsciiExport(Channels, FileNamePath, HeaderLines)
  Dim j, Ch1, ChN, HdrStr, SelChans, ExportGroup, SourceGroup, SourceChan, SourceName
  j = Channels.Count
  HdrStr = GetHdrStr(Channels)
  Ch1 = Channels(1).Name
  ChN = Channels(j).Name
  Channels(1).Name = HeaderLines & vbCRLF & Ch1
  Channels(j).Name = ChN & vbCRLF & HdrStr
  Call DataFileSaveSel(FileNamePath, "CSV", Group.Channels)
  Channels(1).Name = Ch1
End Sub ' GroupAsciiExport()
Function GetHdrStr(Channels)
  Dim j, Channel, HdrStr
  FOR Each Channel In Channels
    HdrStr = HdrStr & ChnDim(Channel)  & vbTAB
  NEXT ' Channel
  HdrStr = Left(HdrStr, Len(HdrStr)-1) & vbCRLF
    HdrStr = HdrStr & ChnComment(Channel) & vbTAB
  NEXT ' j
GetHdrStr = HdrStr
End Function ' GetHdrStr()
' "filename"             specifies the file that is to be read.
' "characterset"         can have two possible values: utf16 (bmp) and ansi. Future possible values include UTF8, etc.
' "delimiter"            is the character used to seperate values. Only tab, semi-colon, and comma will be supported in the first version
' "numstartrow"          is the index of the row to start reading at.
' "firstrowchannelnames" is true if the first row contains the names of the channels following it.
' "firstcolumntime"      indicates that the first column contains time data. These times will be interpreted as absolute times.
' "decimalpoint"         indicates whether a "." or a "," is used to seperate the integral part of the number from the fractional part.
' "timeformat"           indicates what time format to expect in the document and how to write the time format back out again.
Brad
Message 14 of 15
(1,599 Views)
Hi Brad,
thanks a lot for your effort! It seems all is working as planned. 😃
(sorry for the late reply =/ )
Andre
Message 15 of 15
(1,549 Views)
