DIAdem
Bugs while processing *.CSV file format
I have a huge Excel data worksheet and export to MS DOS *.CSV file format to work with DIAdem
1. DIAdem got error when load *.CSV file if the first column is string format.
2. DIAdem loaded a correct *.CSV format but it unable to export file back to *.TDMS format if file too big (my is 70,000 KB).
(4,932 Views)
Hi NiCoder,
The CSV DataPlugin is not a good choice for importing large ASCII files.  We should create a Custom VBScript DataPlugin to import your CSV file-- could you post an example file?  Once loaded into DIAdem correctly, there should be no problem exporting a 70 MB TDMS file.
Brad Turpin
DIAdem Product Support Engineer
(4,923 Views)
