DIAdem
Batch process Report curve width with diadem script
Im having issues applying just a line thinckness to all curves in my REPORT. So heres the story,
I call the Export to PDF tool from labview for each measurement I do. Every measurement has a slightly different report layout that I load from independent files, I use a script once the data has loaded into the report to adjust a few parameters like the axis and curve width. Please see code:
Call GraphObjOpen("2D-Axis1")
Call GraphObjOpen("2DXAxis8_1")
D2AxisXDivMode = "linear"
D2AxisXScaleType = "manual"
D2AxisXBegin = 20
D2AxisXEnd = 20000
D2AxisXOrigin = 20
D2AxisXTick = 1
D2AxisXMiniTick = 4
Call GraphObjClose("2DXAxis8_1")
Call GraphObjOpen("2DYAxis8_1")
D2AxisYDivMode = "linear"
D2AxisYScaleType = "manual"
D2AxisYBegin = -60
D2AxisYEnd = 10
D2AxisYOrigin = -60
D2AxisYTick = 1
D2AxisYMiniTick = 1
Call GraphObjClose("2DYAxis8_1")
Call GraphObjOpen("2DObj2_Curve1")
D2CURVELINEWIDTH = 1
Call GraphObjOpen("2DObj2_Curve2")
Call GraphObjClose("2D-Axis1")
Towards the end of the script I programatically enter in CurveLineWidth adjustments to rectify my lines, but there is a problem. each report seems to use different object names so I often get the error message: Object "2DObj2_Curve1" unknown or not open. Obviously..
How are these objects names chosen by the diadem PDF Report Generation VI? some appear linear like.. curve2, curve3 but then i get names like curve4, curve13!?!? Is it possible to see the script that this VI generates?
Is there any way to do a "foreach" method without using the specific object names???
Or does any other method come to mind???
Help is highly appreciated...
AL.
:. LV2010 SP1 ... W7 .:
(4,307 Views)
Accepted by topic author inversion
Hi Al,
This is the FOR Each approach you requested.  You can also rename those REPORT object by directly editing the TDR file in NotePad or WordPad.  There's also a way to find the names of all the REPORT objects if you don't know the graph is called "2D-Axis1".
  Call GraphObjOpen(D2AxisXObj(1))
  Call GraphObjClose(D2AxisXObj(1))
FOR y = 1 TO AxisNoMax
  IF D2AxisYObj(y) = "" THEN Exit For ' y
  Call GraphObjOpen(D2AxisYObj(y))
  Call GraphObjClose(D2AxisYObj(y))
  FOR c = 1 TO CurveNoMax
    If D2CurveObj(c) = "" Then Exit For ' c
    Call GraphObjOpen(D2CurveObj(c))
      D2CurveLineWidth = 1
    Call GraphObjClose(D2CurveObj(c))
  NEXT ' c
NEXT ' y
Brad Turpin
DIAdem Product Support Engineer
(4,293 Views)
Hi Brad,
Thanks for your snappy reply!
It works! I just used a portion where the curves are applied as I only have one Y-axis...
so here is my generated code:
D2AxisXBegin = 0
D2AxisXEnd = 15
D2AxisXOrigin = 0
D2AxisXTick = 1
D2AxisXMiniTick = 4
D2AxisYScaleType = "complete automatic"
D2AxisYBegin = -60
D2AxisYEnd = 10
D2AxisYOrigin = -60
D2AxisYTick = 1
D2AxisYMiniTick = 1
D2CurveLineWidth = 10
NEXT ' c
Call PicUpdate
When I ran your script out the box it gave me the following error...
Error in <test3.vbs> (Line: 19, Column: 3):
Cannot close object "2DYAxis8_1". Incorrect Name?
but i then saw the error... there was one "  Call GraphObjClose(D2AxisYObj(y))" too many between the NEXT statements 😉
did you mean the code to be like this..
NEXT ' y
NEXT ' c
before it looked like the curves were nested in the Y-axis'? thou that does also make sense... but anyhow the code works great!
Thanks again for your assistance Brad... your presence in this forum is much appreciated i think, you have tackled a few of my issues now relating to diadem 😉
Have a great weekend
AL
Message Edited by ali66b on 02-12-2010 11:54 AM
Message Edited by ali66b on 02-12-2010 11:55 AM
(4,285 Views)
