DIAdem
Automating Diadem Scripts from LabVIEW
Hi all,
I have to specify a LabVIEW application with analyses.
The current application generate tdms files.
Long time after the tests ends, qualification engineers in my enterprise perform Diadem scripts on the tdms files.
So, my idea was to build Diadem scripts once, then automate Diadem from the LV application (Diadem as a client), execute the scripts into Diadem "on the fly", get the results from Diadem and display stuffs like alarms, etc...
Then, later the qualification enginners could use the exact same scripts than the application on the tdms files, without the need to have the LabVIEW application on their computer.
Since the "LabVIEW Diadem Connectivity VIs" are not supported, NI says to use the Diadem ActiveX instead.
However, I find very little informations about this.
My question is : is my idea a wrong idea, and how would you perform the tasks described above ?
(2,971 Views)
Hi Sébastien,
Have you tried using this method?
LabVIEW DIAdem Connectivity VIs for LabVIEW Version 2009 Onwards
I've never used it myself but it is worth a try.
Otherwise, to go back to the activeX method with DIAdem, ave you seen this example?
Junior
(2,939 Views)
