DIAdem
Arrays - Check strict (not approximative) match
Hello Everybody,
I would like to ask if is there a function which looks for exact value of an array. I have been working with the function Filter, which you can see in the next statement to compare a name of a channel with the ones of an array called "ChannelsToKeep":
If UBound(Filter(ChannelsToKeep, ChnName(i)))=-1 Then
But For example if my array contains the values ("mally", "kate", "becks") and I look for "ally" then it will match with "mally", but I don't wish that.
Any suggestion is welcome.
Thank you very much
(2,604 Views)
I realized that the method StrComp is the most appropriate for check strict match between two texts. So it will be very useful for someone who needs that in the future.
(2,564 Views)
