DIAdem
Append time channel
I appended 2 data files. How do I accumulate the time rather than it starting from 0 of the second file?
(875 Views)
you can try to genrate a new time channel. In the analysis module you will find the option "Generate Time channel" or something like this (sorry working with German DIAdem). In the dialog you are able to generate a new time channel with equidistant time steps. Otherwise you can try to use the function ChnGenTime.
regards
(835 Views)
