DIAdem
Announcing DIAdem 2021
DIAdem 2021 is out now and available for download.
The 2021 release of DIAdem includes the new Bird’s Eye View display type, support for Python 3.8 and the ability to select an external Python IDE, add Video Channels to the Data Portal, and include Slider Controls in Dialog Boxes.
Key features include:
General
  • The DIAdem icon in the Windows Start menu shows the major version number.
DIAdem NAVIGATOR, DataFinder, Data Portal
  • In the Data Portal, you can pin new channels automatically.
  • In the Data Portal, you can create video channels by specifying the path to the video file.
DIAdem VIEW
  • With the new "Bird's Eye View" display type in DIAdem VIEW, you can display radar data, including road course, lane, object list, and sensor fields of view, from a bird's eye perspective. You can synchronize this data with GPS data and the detected objects in the video. Use the playback functions of VIEW to start the bird's eye view display and play back the detected objects, the associated measurement data, and the videos concurrently, or move the cursor to a specific point in time.
  • You can move or copy VIEW areas using drag and drop. Moving or copying across different worksheets is also possible. When you move or copy an area and position it behind the last worksheet, you can create a new worksheet at the same time.
DIAdem Script
  • The DIAdem Python environment also supports Python version 3.8.
  • You can specify an external Python IDE and use it to edit Python scripts.
  • The automatically generated header of new Python files contains commands to activate the external debugger. See the help for a detailed description of how to set up the external debugger.
  • When creating new scripts, you can choose whether you prefer VBS or Python as the script language.
  • The short code snippets of the help now show Python code as well as VBS code.
Dialog Editor
  • The slider control provides you with a new input tool in your user dialogs.
For additional information, view the ReadMe.
Message 1 of 1
(2,565 Views)
