DIAdem
Accelerometers Data Zero offsetting
I would like to use Diadem to integrate the output of dynamic accelerometers twice to get position. Is there a good way in Diadem to null out any accelerometer bias offsetting?
Also (RAW or Filtered) which data is use for the Zero offsetting?
Is there any LAW for Data Offsetting?
Please Help me .... (T   T)
(3,900 Views)
Hi Sameera001,
In DIAdem-ANALYSIS you find in the "Base Mathematics" the function "Offset Corrections". It contains several settings, which to use depends on the data you are analyzing.
If you plan to filter your data the order is typically first to correct the offset and then filter the data.
Greetings
Walter
(3,881 Views)
Mr. Walter
Thanks for the reply
I'm using dummy data channels for the filtering... in the mathamatical funtion there are sevaral seletion that have to select.... Please tell me the which one is best for the Bias offseting....
Sameera
(3,877 Views)
