DIAdem
ASCIIConfigLoad - Variable Undefined
I've recently installed DIAdem 2012 and now a script that I've had for a few years does not run, I get the following error:
Variable is undefined: 'ASCIIConfigLoad'
As I understand ASCIIConfigLoad is a command so I don't see why it should be defined, Can anybody help?
Ben
(5,211 Views)
The original ascii gpi dll is not automatically registered in DIAdem 2012.
To make the script work again you have to register it.
Select the following menu entry:
Settings->Options->Extensions->GPI Extensions ...
Press "Add" and select "GfSAscii.dll"
Press "Close"
Save Desctop.ddd and restat DIAdem.
Afterwards the scripts should work again.
P.S.: The functionallity of the ascii dll was replaced by NI dataplugins but I am not sure what your script is doing. Maybe you can create a dataplugin for your files by using the DataPlugin wizard. Maybe there is already a dataplugin for your format on ni.com/dataplugins
(5,204 Views)
