DIAdem
2D scaling using a VBscript
I would like to change the begin and end point of a 2D system using a VBscript inside Diadem . But I have not found an example of how I can use "D2AxisXScaletype" parameter.
I have tried in this way:
Call GraphObjChnClear("2DAxis1")
call GraphObjOpen(D2AxisYObj(D2AxisPairNo(1)))
D2AxisXScaletype= "begin/end manual"
D2AxisXDivMode="linear"
' this is my start point
D2AxisXBegin=chd(1, intNumChannel)
' thjs is my last point
D2AxisXEnd=chd(NumMaxMin, intNumChannel)
call GraphObjClose(D2AxisYObj(D2AxisPairNo(1)))
' Close axis object.
Call GraphObjClose("2DAxis1")
But I generate the following error:
Invalid variable access (D2AXISXSCALETYPE).
Parent object open?
Can someone send my an example of how I should work with "D2AxisXScaletype"?
(3,598 Views)
Hi koniker,
You're close to having the code correct. But you open up the Y axis and then try to edit the X axis scaling method-- that won't work. Try this code instead:
intNumChannel = 1
NumMaxMin = ChnLength(intNumChannel)
Call GraphObjOpen("2DAxis1")
Call GraphObjOpen(D2AxisXObj(1))
D2AxisXScaletype = "begin/end manual"
D2AxisXDivMode = "linear"
D2AxisXBegin = ChDX(1, intNumChannel)
D2AxisXEnd = ChDX(NumMaxMin, intNumChannel)
Call GraphObjClose(D2AxisXObj(1))
Call PicUpdate
Cheers,
Brad Turpin
DIAdem Product Support Engineer
(3,587 Views)
Thanks very much for your reply. I will try it.
(3,576 Views)
