DIAdem
2019 Rename Groups
When you right click on a group in previous versions you could rename the group. In 2019 this feature is grayed out, why is this? I was able to change the name via code, but that seems a bit cumbersome.
(3,154 Views)
I see you can also change the group name if you click inside the "name" field of the properties list directly below the Data Portal.  That is too bad that the right-click option has been disabled.
(3,143 Views)
Just to have a graphical illustration of what Julia was referring to, you can click on the group name and then edit the name below in the box I highlighted in red.
(3,088 Views)
