DIAdem
2017 Result Properties name change
So I just started using version 2017 and noticed that due to the new property organization, the property name from calculation results have changed.
Specifically, I've been working with the StatBlockCalc call in the script. In 2015, this created a property called "ResultStatArithMean" and now the resulting property is "Result~Statistics~MeanValues~ArithmeticMean".
I have several scripts that rely on using Channel.Properties.Exists("Name of Property") to check if a property exists, then do something based on the result or set a variable to that value. Now my scripts that I developed in 2015 doesn't appear to work when I try to run it in 2017 because of this name change.
Is there a recommended way to update my scripts to work with 2017 as well as maintain backwards compatibility?
Nick
(3,389 Views)
Accepted by topic author meatballosaurus
Accessing the properties still works with the old names while Exists returns false.
So it was tried to not break the scripts.
option explicit
data.Root.Clear
Call DataFileLoad("EXAMPLE.TDM","","Load")
call ChnStatisticsChannelCalc("[1]/[2]",98,0,0,0,0,0,"NameName")
dim txt : txt = ""
txt = txt & "Exists new " & data.root.ChannelGroups(1).Channels(2).Properties.Exists("Result~Statistics~MeanValues~ArithmeticMean") & VBCRLF
txt = txt & "Exists old " & data.root.ChannelGroups(1).Channels(2).Properties.Exists("ResultStatArithMean") & VBCRLF
txt = txt & "Value new " & data.root.ChannelGroups(1).Channels(2).Properties("Result~Statistics~MeanValues~ArithmeticMean").value & VBCRLF
txt = txt & "Value old " & data.root.ChannelGroups(1).Channels(2).Properties("ResultStatArithMean").value & VBCRLF
MsgBox txt
To generate Code that works with 2015 and 2017 you need to exchange the Exists code
  • Create an different method
    option explicit
    ' create an instance to be used in script
    data.Root.Clear
    dim i : for i = 1 to 23 : StatSel(i) = "No" : next
    StatSel(6)       = "Yes"
    StatClipCopy     = 0
    StatClipValue    = 0
    StatFormat       = ""
    StatResChn       = 0
    StatResChnNames  = 0
    StatResChnNameFormat= "NameName"
    Call StatBlockCalc("Channel","1-","[1]/[2]")
    dim txt : txt = ""
    txt = txt & "Value new " & IsEmpty(GetResultVal(data.root.ChannelGroups(1).Channels(2),"Result~Statistics~MeanValues~ArithmeticMean")) & VBCRLF
    txt = txt & "Value old " & IsEmpty(GetResultVal(data.root.ChannelGroups(1).Channels(2), "ResultStatArithMean")) & VBCRLF
    MsgBox txt
    function GetResultVal(byref chO, byref propertyName)
      GetResultVal = vbEmpty
      on error resume next
        GetResultVal = chO.Properties("ResultStatArithMean").value
      on error goto 0
    end function
  • Map the names based on the Program version
    I created a script based on the mapping table of the DIAdem help that works in DIAdem 2015 and 2017 using a Name mapper helper class CMapPropNames.
option explicit
dim mp : set mp = new CMapPropNames
data.Root.Clear
StatSel(6)       = "Yes"
StatClipCopy     = 0
StatClipValue    = 0
StatFormat       = ""
StatResChn       = 0
StatResChnNames  = 0
dim txt : txt = ""
txt = txt & "Exists new " & data.root.ChannelGroups(1).Channels(2).Properties.Exists(mp.M("ResultStatArithMean")) & VBCRLF
txt = txt & "Value new " & data.root.ChannelGroups(1).Channels(2).Properties(mp.M("ResultStatArithMean")).value & VBCRLF
MsgBox txt
class CMapPropNames
  function M(byRef name)
    if dict.Exists(name) then
      M = dict.item(name)
    else
      M = name
    end if
  end function
  Private Sub Class_Initialize()
    set dict = CreateObject("Scripting.Dictionary")
    dict.CompareMode = vbTextCompare
    if ProgramVersion < 17 then
      ' no mapping needed
      exit sub
    end if
    dict.Add "DAC_Calibration_ExpirationDate", "DAC~Calibration~ExpirationDate"
    dict.Add "DAC_Channel_HighRange", "DAC~Channel~HighRange"
    dict.Add "DAC_Channel_Id", "DAC~Channel~Id"
    dict.Add "DAC_Channel_Info", "DAC~Channel~Info"
    dict.Add "DAC_Channel_LowRange", "DAC~Channel~LowRange"
    dict.Add "DAC_Device_Id", "DAC~Device~Id"
    dict.Add "DAC_Device_Name", "DAC~Device~Name"
    dict.Add "DAQ_Calibration_Date", "DAQ~Calibration~Date"
    dict.Add "NI_Sensor_TEDSCalibrationDate", "NI~Sensor~TEDS~CalibrationDate"
    dict.Add "NI_Sensor_TEDSCalibrationInitials", "NI~Sensor~TEDS~CalibrationInitials"
    dict.Add "NI_Sensor_TEDSCalibrationPeriod", "NI~Sensor~TEDS~CalibrationPeriod"
    dict.Add "NI_Sensor_TEDSManufacturer", "NI~Sensor~TEDS~Manufacturer"
    dict.Add "NI_Sensor_TEDSManufacturerID", "NI~Sensor~TEDS~ManufacturerID"
    dict.Add "NI_Sensor_TEDSMeasurementLocationID", "NI~Sensor~TEDS~MeasurementLocationID"
    dict.Add "NI_Sensor_TEDSModelID", "NI~Sensor~TEDS~ModelID"
    dict.Add "NI_Sensor_TEDSSerialNumber", "NI~Sensor~TEDS~SerialNumber"
    dict.Add "NI_Sensor_TEDSType", "NI~Sensor~TEDS~Type"
    dict.Add "NI_Sensor_TEDSVersionLetter", "NI~Sensor~TEDS~VersionLetter"
    dict.Add "NI_Sensor_TEDSVersionNumber", "NI~Sensor~TEDS~VersionNumber"
    dict.Add "ResultACompAverage", "Result~AComp~Average"
    dict.Add "ResultACompEndTime", "Result~AComp~EndTime"
    dict.Add "ResultACompVersion", "Result~AComp~Version"
    dict.Add "ResultASIMax", "Result~ASI~Max"
    dict.Add "ResultASIVersion", "Result~ASI~Version"
    dict.Add "ResultApprAnsatzCoef1", "Result~Approximation~AnsatzFunction~Coefficient1"
    dict.Add "ResultApprAnsatzCoef2", "Result~Approximation~AnsatzFunction~Coefficient2"
    dict.Add "ResultApprAnsatzCoef3", "Result~Approximation~AnsatzFunction~Coefficient3"
    dict.Add "ResultApprAnsatzName1", "Result~Approximation~AnsatzFunction~Name1"
    dict.Add "ResultApprAnsatzName2", "Result~Approximation~AnsatzFunction~Name2"
    dict.Add "ResultApprAnsatzName3", "Result~Approximation~AnsatzFunction~Name3"
    dict.Add "ResultApprFctStr", "Result~Approximation~ModelFunction"
    dict.Add "ResultApprPrecision", "Result~Approximation~Precision"
    dict.Add "ResultCorridorCheck", "Result~CorridorCheck"
    dict.Add "ResultCorridorCheckTIdx", "Result~CorridorCheck~TIdx"
    dict.Add "ResultCorridorCheckVersion", "Result~CorridorCheck~Version"
    dict.Add "ResultDCLevel", "Result~ACDCCoupling~DCLevel"
    dict.Add "ResultGaussFitAmplitude", "Result~GaussFit~Amplitude"
    dict.Add "ResultGaussFitCenter", "Result~GaussFit~Center"
    dict.Add "ResultGaussFitResidue", "Result~GaussFit~Residue"
    dict.Add "ResultGaussFitStdDev", "Result~GaussFit~StandardDeviation"
    dict.Add "ResultGenLSFitMSE", "Result~GeneralLSLinearFit~MSE"
    dict.Add "ResultHCD15MeanAcc", "Result~HCD15~MeanAcceleration"
    dict.Add "ResultHCD15T1", "Result~HCD15~T1"
    dict.Add "ResultHCD15T2", "Result~HCD15~T2"
    dict.Add "ResultHCD15Value", "Result~HCD15~Value"
    dict.Add "ResultHCD36MeanAcc", "Result~HCD36~MeanAcceleration"
    dict.Add "ResultHCD36T1", "Result~HCD36~T1"
    dict.Add "ResultHCD36T2", "Result~HCD36~T2"
    dict.Add "ResultHCD36Value", "Result~HCD36~Value"
    dict.Add "ResultHCDMeanAcc", "Result~HCD~MeanAcceleration"
    dict.Add "ResultHCDT1", "Result~HCD~T1"
    dict.Add "ResultHCDT2", "Result~HCD~T2"
    dict.Add "ResultHCDUser", "Result~HCDUser~WindowWidth"
    dict.Add "ResultHCDUserMeanAcc", "Result~HCDUser~MeanAcceleration"
    dict.Add "ResultHCDUserT1", "Result~HCDUser~T1"
    dict.Add "ResultHCDUserT2", "Result~HCDUser~T2"
    dict.Add "ResultHCDUserValue", "Result~HCDUser~Value"
    dict.Add "ResultHCDValue", "Result~HCD~Value"
    dict.Add "ResultHCDVersion", "Result~HCD~Version"
    dict.Add "ResultHCDdMeanAcc", "Result~HCDd~MeanAcceleration"
    dict.Add "ResultHCDdT1", "Result~HCDd~T1"
    dict.Add "ResultHCDdValue", "Result~HCDd~Value"
    dict.Add "ResultHIC15MeanAcc", "Result~HIC15~MeanAcceleration"
    dict.Add "ResultHIC15T1", "Result~HIC15~T1"
    dict.Add "ResultHIC15T2", "Result~HIC15~T2"
    dict.Add "ResultHIC15Value", "Result~HIC15~Value"
    dict.Add "ResultHIC36MeanAcc", "Result~HIC36~MeanAcceleration"
    dict.Add "ResultHIC36T1", "Result~HIC36~T1"
    dict.Add "ResultHIC36T2", "Result~HIC36~T2"
    dict.Add "ResultHIC36Value", "Result~HIC36~Value"
    dict.Add "ResultHICMeanAcc", "Result~HIC~MeanAcceleration"
    dict.Add "ResultHICT1", "Result~HIC~T1"
    dict.Add "ResultHICT2", "Result~HIC~T2"
    dict.Add "ResultHICUser", "Result~HICUser~WindowWidth"
    dict.Add "ResultHICUserMeanAcc", "Result~HICUser~MeanAcceleration"
    dict.Add "ResultHICUserT1", "Result~HICUser~T1"
    dict.Add "ResultHICUserT2", "Result~HICUser~T2"
    dict.Add "ResultHICUserValue", "Result~HICUser~Value"
    dict.Add "ResultHICValue", "Result~HIC~Value"
    dict.Add "ResultHICVersion", "Result~HIC~Version"
    dict.Add "ResultHICdMeanAcc", "Result~HICd~MeanAcceleration"
    dict.Add "ResultHICdT1", "Result~HICd~T1"
    dict.Add "ResultHICdValue", "Result~HICd~Value"
    dict.Add "ResultHPC15MeanAcc", "Result~HPC15~MeanAcceleration"
    dict.Add "ResultHPC15T1", "Result~HPC15~T1"
    dict.Add "ResultHPC15T2", "Result~HPC15~T2"
    dict.Add "ResultHPC15Value", "Result~HPC15~Value"
    dict.Add "ResultHPC36MeanAcc", "Result~HPC36~MeanAcceleration"
    dict.Add "ResultHPC36T1", "Result~HPC36~T1"
    dict.Add "ResultHPC36T2", "Result~HPC36~T2"
    dict.Add "ResultHPC36Value", "Result~HPC36~Value"
    dict.Add "ResultHPCMeanAcc", "Result~HPC~MeanAcceleration"
    dict.Add "ResultHPCT1", "Result~HPC~T1"
    dict.Add "ResultHPCT2", "Result~HPC~T2"
    dict.Add "ResultHPCUser", "Result~HPCUser~WindowWidth"
    dict.Add "ResultHPCUserMeanAcc", "Result~HPCUser~MeanAcceleration"
    dict.Add "ResultHPCUserT1", "Result~HPCUser~T1"
    dict.Add "ResultHPCUserT2", "Result~HPCUser~T2"
    dict.Add "ResultHPCUserValue", "Result~HPCUser~Value"
    dict.Add "ResultHPCValue", "Result~HPC~Value"
    dict.Add "ResultHPCVersion", "Result~HPC~Version"
    dict.Add "ResultHPCdMeanAcc", "Result~HPCd~MeanAcceleration"
    dict.Add "ResultHPCdT1", "Result~HPCd~T1"
    dict.Add "ResultHPCdValue", "Result~HPCd~Value"
    dict.Add "ResultMeanPulsePeriod", "Result~PulseDetection~MeanPulsePeriod"
    dict.Add "ResultMeanSpeed", "Result~PulseDetection~MeanSpeed"
    dict.Add "ResultMissingPulses", "Result~PulseDetection~MissingPulses"
    dict.Add "ResultNICRearMax", "Result~NICRear~Max"
    dict.Add "ResultNICRearTime", "Result~NICRear~Time"
    dict.Add "ResultNICRearVersion", "Result~NICRear~Version"
    dict.Add "ResultNijMax", "Result~Nij~Max"
    dict.Add "ResultNijTime", "Result~Nij~Time"
    dict.Add "ResultNijVersion", "Result~Nij~Version"
    dict.Add "ResultNonLinearFitCoef1..20", "Result~NonLinearFit~Coefficient1..20"
    dict.Add "ResultNonLinearFitCoefName1..20", "Result~NonLinearFit~CoefficientName1..20"
    dict.Add "ResultNonLinearFitMSE", "Result~NonLinearFit~MSE"
    dict.Add "ResultNonLinearFitModelFunction", "Result~NonLinearFit~ModelFunction"
    dict.Add "ResultOIVTimeFlight", "Result~OIV~TimeFlight"
    dict.Add "ResultOIVVelocity", "Result~OIV~Velocity"
    dict.Add "ResultOIVVersion", "Result~OIV~Version"
    dict.Add "ResultORAMax", "Result~ORA~Max"
    dict.Add "ResultORATime", "Result~ORA~Time"
    dict.Add "ResultORAVersion", "Result~ORA~Version"
    dict.Add "ResultOptDataTypeRoundingError", "Result~OptDataType~RoundingError"
    dict.Add "ResultOptDataTypeStorageSavings", "Result~OptDataType~StorageSavings"
    dict.Add "ResultPHDMax", "Result~PHD~Max"
    dict.Add "ResultPHDTime0", "Result~PHD~Time0"
    dict.Add "ResultPHDTime", "Result~PHD~Time"
    dict.Add "ResultPHDVersion", "Result~PHD~Version"
    dict.Add "ResultPulseLimit", "Result~PulseLimit"
    dict.Add "ResultPulseLimitTIdx", "Result~PulseLimit~TIdx"
    dict.Add "ResultPulseLimitVersion", "Result~PulseLimit~Version"
    dict.Add "ResultRegrCoeffA", "Result~Regression~CoefficientA"
    dict.Add "ResultRegrCoeffB", "Result~Regression~CoefficientB"
    dict.Add "ResultRegrName", "Result~Regression~Name"
    dict.Add "ResultRegrPrecision", "Result~Regression~Precision"
    dict.Add "ResultRoundingError", "Result~Rounding~Error"
    dict.Add "ResultSINADDetectedFrequency", "Result~SINAD~DetectedFrequency"
    dict.Add "ResultSINADResult", "Result~SINAD~Value"
    dict.Add "ResultSINADTHDPlusNoise", "Result~SINAD~THDPlusNoise"
    dict.Add "ResultSPCCp", "Result~SPC~CapabilityIndexes~Cp"
    dict.Add "ResultSPCCpL", "Result~SPC~CapabilityIndexes~CpL"
    dict.Add "ResultSPCCpU", "Result~SPC~CapabilityIndexes~CpU"
    dict.Add "ResultSPCCpk", "Result~SPC~CapabilityIndexes~Cpk"
    dict.Add "ResultSPCFracNConf", "Result~SPC~NonconformingParts~FracNConf"
    dict.Add "ResultSPCLFracNConf", "Result~SPC~NonconformingParts~LowerFracNConf"
    dict.Add "ResultSPCLowerNPL", "Result~SPC~Limits~LowerNPL"
    dict.Add "ResultSPCProcessMean", "Result~SPC~ProcessMean"
    dict.Add "ResultSPCProcessSigma", "Result~SPC~ProcessSigma"
    dict.Add "ResultSPCUFracNConf", "Result~SPC~NonconformingParts~UpperFracNConf"
    dict.Add "ResultSPCUpperNPL", "Result~SPC~Limits~UpperNPL"
    dict.Add "ResultSingleToneAmplitude", "Result~SingleTone~Amplitude"
    dict.Add "ResultSingleToneFrequency", "Result~SingleTone~Frequency"
    dict.Add "ResultSingleTonePhase", "Result~SingleTone~Phase"
    dict.Add "ResultStatArithMean", "Result~Statistics~MeanValues~ArithmeticMean"
    dict.Add "ResultStatAvDevMean", "Result~Statistics~AverageAbsDeviation~FromMean"
    dict.Add "ResultStatAvDevMedian", "Result~Statistics~AverageAbsDeviation~FromMedian"
    dict.Add "ResultStatDeviation", "Result~Statistics~Dispersion~StandardDeviation"
    dict.Add "ResultStatGeoMean", "Result~Statistics~MeanValues~GeometricMean"
    dict.Add "ResultStatHarMean", "Result~Statistics~MeanValues~HarmonicMean"
    dict.Add "ResultStatKurtosis", "Result~Statistics~Form~Kurtosis"
    dict.Add "ResultStatLowerQuartile", "Result~Statistics~Quantiles~LowerQuartile"
    dict.Add "ResultStatMax", "Result~Statistics~ExtremeValues~Maximum"
    dict.Add "ResultStatMedian", "Result~Statistics~Quantiles~Median"
    dict.Add "ResultStatMin", "Result~Statistics~ExtremeValues~Minimum"
    dict.Add "ResultStatQuartilDist", "Result~Statistics~Dispersion~QuartileDistance"
    dict.Add "ResultStatRange", "Result~Statistics~Dispersion~Range"
    dict.Add "ResultStatRelVarCoeff", "Result~Statistics~Dispersion~RelativeVariationCoefficient"
    dict.Add "ResultStatSkew", "Result~Statistics~Form~Skewness"
    dict.Add "ResultStatSqrMean", "Result~Statistics~MeanValues~SquareMean"
    dict.Add "ResultStatStdError", "Result~Statistics~Dispersion~StandardError"
    dict.Add "ResultStatSum", "Result~Statistics~Sums~Sum"
    dict.Add "ResultStatSumSqr", "Result~Statistics~Sums~SumOfSquares"
    dict.Add "ResultStatUpperQuartile", "Result~Statistics~Quantiles~UpperQuartile"
    dict.Add "ResultStatVarCoeff", "Result~Statistics~Dispersion~VariationCoefficient"
    dict.Add "ResultStatVariance", "Result~Statistics~Dispersion~Variance"
    dict.Add "ResultTHIVFlailSpace", "Result~THIV~FlailSpace"
    dict.Add "ResultTHIVTimeFlight", "Result~THIV~TimeFlight"
    dict.Add "ResultTHIVVelocity", "Result~THIV~Velocity"
    dict.Add "ResultTHIVVersion", "Result~THIV~Version"
    dict.Add "ResultTIRes", "Result~TI~Value"
    dict.Add "ResultTITime", "Result~TI~Time"
    dict.Add "ResultTIVersion", "Result~TI~Version"
    dict.Add "ResultTTIRes", "Result~TTI~Value"
    dict.Add "ResultTTIVersion", "Result~TTI~Version"
    dict.Add "ResultUsedPulses", "Result~PulseDetection~UsedPulses"
    dict.Add "ResultXOffset", "Result~XOffset"
    dict.Add "ResultXOffsetCorrCoefficient", "Result~XOffset~CorrelationCoefficient"
    dict.Add "ResultXOffsetDeltaN", "Result~XOffset~DeltaN"
    dict.Add "ResultXOffsetDeltaT", "Result~XOffset~DeltaT"
    dict.Add "ResultXgDeltaX", "Result~Xg~DeltaX"
    dict.Add "ResultXgMaxPeak", "Result~Xg~MaxPeak"
    dict.Add "ResultXgTimeBegin", "Result~Xg~TimeBegin"
    dict.Add "ResultXgTimeEnd", "Result~Xg~TimeEnd"
    dict.Add "ResultXgVersion", "Result~Xg~Version"
    dict.Add "ResultXmsAcceleration", "Result~Xms~Acceleration"
    dict.Add "ResultXmsDeltaX", "Result~Xms~DeltaX"
    dict.Add "ResultXmsTimeBegin", "Result~Xms~TimeBegin"
    dict.Add "ResultXmsTimeEnd", "Result~Xms~TimeEnd"
    dict.Add "ResultXmsVersion", "Result~Xms~Version"
  end sub
  private dict
end class
(3,340 Views)
Thanks, this is what I was looking for.
(3,320 Views)
