XLR8 2.3
(available soon in the LVTN)
- new polymorphic function "color Area"
- new function "Get Cellstyle"
- "write to named range" automaticly selects the corresponding sheet (#928)
- "close Workbook" outputs the original file path (#1196)
- "close Workbook" input "save file" is recommended not required (#1196)
- "format Area" policy bug fixed (#1176)
- "Wrap Text" style bug fixed (#1173)
- "hyperlink" bug in xlsx fixed (#804)
- "get named ranges" outputs the corresponding sheet with the correct rows and columns (#984)
- "delete sheet" removes corresponding named ranges (#798)
- "read Area" reading below last row bug (#802)
- "WriteCell (Date)", "FormatCell (custom)" and "FormatArea (custom)" error Message after second iteration fixed
- performance improvements in style handling
- improved memory handling
Hi Peter,
Cheched on XLR8 2.3.1.7: #1196, #1176,#984, #802.
Daniel
