DASYLab
not stable output values
1) dasylab 9.0
2)personal daq/3000 series 16 bit/1-mhz usb data aquisition system
We take measurements in volts and with an equation in input module we take kg
the values appear unstable continiously in the displays windows.
How we can make the values stable ?
(6,651 Views)
This is a normal effect with data acquisition system especially block based.  you have three options
- reduce the sample rate to a logical frequency.  No need to use 10Khz when you only need 10Hz
- filter the signal before it goes into the display.  This is what I usually do
- use the average to reduce the points
Tom
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,649 Views)
