DASYLab
maxium
I have 10 output numbers from Statistical values module, and I need to pull out highest and lowest number from those 10 numbers.  should I use Formula Interpreter to do it? and how?  (I'm using Dasylab V11)
-J
(5,954 Views)
You can use two arithmetic module, select "operation with all channels" set first module to output minimum and second module to maximum, see attached worksheet.
Rgds.
Pesko
(5,927 Views)
great, thanks!!!
(5,925 Views)
