DASYLab
formula interpreter not enabled
Any good reason why my Formula Intepreter is not enabled in dasyLab 12?  Window 8.1 OS.
(8,516 Views)
The Formula interpreter is not available in DASYLab Lite.
See the list of modules by version here
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,515 Views)
Pretty sure its the Pro version, this is the only module not enabled see attached
(8,511 Views)
Okay. That's funky.
Go to the options menu, select Global settings, and turn on "show all start messages"
Go to View menu, and enable the info area and console.
Close and restart.
Look in the console, and see if formel.dll loaded.
If it did not, check the C:\Program Files\DASYLab 12.0 folder to see if formel.dll is in the list.
If not... can you call in? Contact us at Measurement Computing.
(8,506 Views)
I un-installed Dasylab and associated "stuff" reinstalled and found that my Anti-virus software was quarantining formel.dll.  I added this file as an exception and reinstalled.  Everything seemed fine unitl I tried to add my MCC device with the configurator and I get the attached error.  As far as I can tell the drivers are not installed so there is nothing to remove in the control panel.
(8,463 Views)
Wow.. That is a new one.
Is there an mcdasylabdriver.msi in the program files folder for DASYLab?
If so, run it, and uninstall.
(8,460 Views)
Accepted by topic author Falizar
Thanks for the help CJ, the file you directted me to worked great!
(8,437 Views)
