DASYLab
formula interpreter logical operator
Dasylab 10
I'm capturing voltage from a daq, using formula interpreter to make calculations and then generating a XY graph. As the values are being generated I am wanting to display in a digital display the Y peak value and the corresponding X value. I therefore thought of writing to a variable each time the new value measured is greater the last one and then transmitting this to the display...
Problem: I don't know how to use the formula interpreter and the logical operators
e.g. IN(0)>=${VAR1}
When true, I'm expecting to see the output of the formula interpreter to go high and then I can trigger an action event. However whatever I have attempted so far hasn't worked, so I'm guessing there is something I don't understand
Can anyone show me an example of how this works?
(6,802 Views)
Accepted by topic author T.S.Dyno
Spoiler
The result will be 1 and not 5 if true.  You need to moltiply the result by 5.
So, if your formula is IN(0)>=${VAR1} then you need to change it to (IN(0)>=${VAR1}) * 5
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,796 Views)
Hi T.S.Dyno,
I understand you're having some issues with DasyLab.
Just to check I have understood correctly, can you confirm/correct the following:
Voltage Input > Formula Interpreter Calculations > Generate XY Graph > Display Y Peak > Find Corresponding X
Would you be able to send me a copy of your code so that I can get a better understanding of what you have tried so far?
Kind Regards,
Oli
LabVIEW Student Ambassador
National Instruments UK
(6,793 Views)
Thanks to all. Tom's answer solved the issue for me. You get a result of 1 but this needs multiplying by 5 to generate a logic level that can be used with logic inputs and events.
(6,779 Views)
