DASYLab
display system time in layout, system variable does not seem to work...
Hi All,
Looking for some guidance, I have a layout set that gives a summary of several values every 5 miutes and I wish to provide a time stamp ( just normal computer clock type of time display HH:MM:SS) of when the current values were taken. I have read the help files  and found a global variable  ${TIME} and also found references to ${ACTUAL_HOUR}, ${ACTUAL _MINUTE} etc variables, however when I try and use ${TIME} it doesn't work and reverts to ${VAR_1} in the module.
Is the ${TIME} variable still active in version 12 or is it a leftover from previous versions? if this is the case how do I get around this and compile a normal time data string from the component variables that do seem to report back the system time?
I am on the current release with service pack...
Any help appreciated.
Tim
(5,617 Views)
${TIME} is a global string. You can't use it in a module - only in the layout.
Use it in the layout by creating a Text Line object. You'll have the current time displayed on the layout.
In the worksheet, you can use the Special-TimeBase module to generate the time as a channel, and you can display that in a Digital meter using the Clock mode.
You could also use the Control-Write Block Time module to write that information to a Global string that you can then display using the Text Line object.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,611 Views)
