DASYLab
comparing strings
I need to compare two strings for identical values. One is my input as test data, the other is coming in over the RS232 interface. I'd like to compare the RS232 output to my data for accuracy.
JLW
(6,148 Views)
You can do the comparison in the strings/variables...
Create a variable, and define a formula for it (Definition in V12, Extended in earlier versions). The result is 0 or 1 ...
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,147 Views)
AH Ha, I knew there had to be a way.
Thanks, I'll try it
JLW
(6,145 Views)
