DASYLab
communicating with pico PT 104 logger
Hi
Has anyone had experiance of communicating with Pico PT104 temperature logger with dasylab
(5,816 Views)
PICO has a programmer manual which says that it requires a software program to use its API to communicate with the devices.
From DASYLab's point of view, that means that you would have to write a driver using the Extension Toolkit.
Drivers like this typically require an experienced C Programmer, with Windows knowledge. It could take anywhere from one week to 6 months to write the driver, depending on the scope and complexity of the PICO API and the desires of a customer.
You could contact PICO and ask them if they plan to write a driver.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,807 Views)
