DASYLab
Using a VAR to set list length property
Hi Folks,
Is it possible to use a global variable to set the list box length property? I want to be able to select this from within a layout using a coded switch. For example, i want to use the switch to select between 2000,4000,6000 or 9999 list box lengths. The coded switch would write to th evariable and the listbox property would read the variable for its value.
Regards
Willie
(3,731 Views)
Accepted by topic author WillieNHS
Hi Willie,
It appears that the List module does not support variables or strings.
I'll add it to the list Smiley Happy
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(3,717 Views)
Thanks again CJ.
Willie
(3,696 Views)
