DASYLab
Using IOtech Daq/112 under DasyLAB
Hi there!
I try to get my Daq/112 to work under DasyLab. I select the appropriate driver from IOtech, then I configure the Hardware, DasyLab shows everything correctly. But when I try with a testsheet consisting of an A/D Module and a Yt-Chart and try to run I get the error message:
"Communication can not be established. Verify interface connection and power. Also check the interface settings in the Control Panel."
The hardware is correctly installed because the delivered utility succeeds when doing a hardware check. What do I have to configure else in DasyLab?
Thanx!
(9,051 Views)
Generally, we ask you to contact IOtech directly for questions related to their hardware and drivers. They wrote and maintain the drivers for DASYLab for all IOtech devices.
You should verify the following:
--run the DAQ Configuration Utility - detect and verify the DAQ/112 card. There is a Test panel that allows you to test the IRQ, base address, and throughput.
--run DASYLab, go to Experiment/Hardware Setup, and exactly match the configuration in the DAQ Configuration utility. It must be done manually; it does not pick up the configuration automatically.
If this does not work.... www.iotech.com
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(9,051 Views)
thanx!
your second advice helped much!
bye, DAve
(9,051 Views)
