DASYLab
Transfer function dasylab
Hi!
I need to develop a trasnfer fuction.
I only have the output signal and the characteristic of the system in the Laplace domain. I need to develop the transfer fucntion of this system to find out the input signal.
¿How can I do it? The "Transfer Function Module" is not valid for this case, because I only have one signal, and the formula of the system.
(8,108 Views)
What is the formula for the system? Have you considered the Formula module?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,091 Views)
This module isnt's able to work in the frecuency domain. I need use the Laplace Transform. Thanks.
(8,066 Views)
Hi
First invert your Laplace transfer function and apply the z transform, put the coefficients of the z transfert function (numerator and denominator) in the universal filter module (have a look also to convolution module), read your output signal (file read module) connect to your filter and display the result on arecorder module : should be your input signal!!!
Easy with Dasylab, isn't it ???
Frédéric Miqueau
MD Electronic, France
http://www.mdelectronic.fr
French Dasylab Forum : http://www.dasylab-forum.de/forum/index.php?showforum=43
(7,864 Views)
