DASYLab
Time Measurement of 2 Max peak analog input
I am relative new using Dasylab.
I have a phototransistor connected to the USB-2404-UI. I would like to get the time between two peaks.
Example:
I take a flashlight and turn it on, I get 7V peak. Turn it off, then it gets to around 0 and then turn it on again to 7V.
What is the best way to get the time between the flashes?
Thank you in advance,
(2,632 Views)
Connect the Analog Input to a Combi Trigger. Set the trigger to start and stop using Threshold Value Exceeded. Use 6 volts for the Threshold value. This will generate a pulse with a length equal to the time. Use the Pulse Analysis module to measure the time and a Latch to hold the time.
(2,604 Views)
Thank you very much!
It worked perfect,
Erik
(2,476 Views)
