DASYLab
Slow Data refresh DASYLab 2016
Dear Forum,
I am quite new to DASYLab so I don't know what exactly I am doing wrong.
When I create a simple DASYLab file consisting of a Sinus generator and a digital display or Y/t diagram, the data only refreshes about twice or thrice a second. What I want is a constant flow of data that is being visualized instead of data that refreshes slowly.
I have already played around with the sampling rate and blocksize but with no results. The computer is by now means underequipped hardwarewise.
Thanks in advance for anyone helping.
(3,605 Views)
The Y/t Chart displays complete blocks of data at a time, then refreshes to display the next block.
It serves well for "fast" data. The block size/sample rate ratio will determine the refresh rate. If your block size is 100 and the sample rate is 1000, it should refresh every 100/1000 of a second, or every 100 ms.
If your block size/sample rate ratio is too small (depends on the computer), then the Y/t Chart may not be able to keep up. I've also seen an issue with the Chart Recorder if you have a block interval of 1 ms or less. Even a good computer won't help.
If your block size and sample rate are very large (block size greater than 32K), there is a known problem with the Y/t Chart in DASYLab 2016. See the "New in this release" section of the online help for more information. DASYLab 2020 addressed some of the issues.
The Y/t Chart can be configured to display multiple blocks at a time. If you display 5 blocks, it waits for all five. You can configure a Wiper or Fast Recorder mode if your block size is greater than 256.
--cj --DASYLab Pro -- Retired --- I am no longer employed by NI or Measurement Computing. My opinions are just that, seasoned by 25+ years of working with DASYLab. Please contact www.MeasX.com or www.mccdaq.com for active support options.
(3,425 Views)
