DASYLab
Slider - setting via global variables
Dear friends. Is there any possibility to change the "maximum value" at the slider module externally, using with the global variable?
I am programming the communication with TSA syringe pump and I need to change the range of charging rate according the used diameter of the syringe. I can prepare six different sliders for each diameter, but it is too inconvenient. Do you anybody have any idea? I tested put the variable to maximum value at the slider module field, but only a number was possible.
(6,438 Views)
Accepted by topic author BobPupak
What version of DASYLab are you using?
My slider module with DASYLab 12 allows a Global Variable for the Min and Max, and it changes while running.
One way to tell if a Global Variable is supported... right click in the parameter field.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,429 Views)
I use the version 12(full). You are right, this way it is possible. I tried to do it directly (writing the name of the global variable to the field - it was impossible) and at help I didn’t find anything as well.
Thank you very much.
(6,425 Views)
