DASYLab
Signal router
I have dasylab 8.  I would like to use the signal router.  Except it works exactly opposite like I need.  The module has 1 input and multiple outputs that you can route to depending on your control scheme.  I would like to take multiple signals, and depending on my control scheme, route it to a single output (say a recorder module or a write module).
So, to summarize, I have multiple inputs and depending on what is happening within the process, route a single signal to a display module or write module.  The routing is all manual user control.
Thanx
BoB
(6,775 Views)
The corresponding many-to-one channel module is called the Time Slice module, cleverly hidden in the Data Reduction group. You can use it with a control input (Amplitude controlled) or use time to change the channels.
The example, Waveform Generator.dsb, uses this module very effectively, with a labeled Coded Switch module controlling theTime Slice module.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,774 Views)
